rear suspension noise
Old 11-20-2007 | 05:05 PM
JULIAMERRUS's Avatar
Default rear suspension noise
My car has a realy bad rattle and clunking sound at the back right of my car. I had the springs replaced on the rear of my car some time ago and the rattle started later. My husband looked under the car and saw the bottom of the springs were mounted on some metal and rubber caps and seemed ok, but wasnt sure whether the top of the springs and what they placed inwere in order.What are the rear springs mounted into and is this the problem?
Julia (worried)
Old 01-12-2008 | 01:48 PM
A Class Widow's Avatar
Default RE: rear suspension noise
Hi, my wife has a 2000 A160 and after having had the rear coil spirngs replaced the noise was still apparent - it is the location bolts for the rear trailing arms. Theypivot forward of the rear wheels and are subject to wear. It would be worth havign the rear brake hose checked at the same time as this has to be removed (I believe) before the bolts can be replaced (wear is due to the rubber or poly sleeving/bush that they sit in, wearing out.
Old 02-09-2008 | 08:18 AM
designowagon's Avatar
I have an 02 E320 4matic wagon with self leveling shocks. Does anyone know how to bleed the system after replacing the rear shocks?
Old 03-31-2008 | 09:35 AM
chittychittybangbang's Avatar
what about anti-roll links ? do you get them in the back?
my car had that clanking banging noise and the front ones were replaced.
it's ok now.
Frank ch
11-28-2011 07:50 PM
My wifes C
08-01-2006 01:47 PM
C230 Sport
02-17-2006 10:08 PM
Mr.MB
02-28-2005 01:12 PM
fraguada1
10-27-2004 01:19 PM
