Mercedes CL Class Mercedes CL500 and Mercedes CL600 Coupes.
my tandum pump needs replacing any help??
Old Oct 28, 2008 | 04:35 PM
ara's Avatar
ara
Default my tandum pump needs replacing any help??
after my abs light went on and seeing lots of hydrolic loss in driveway, my mechanic says i need to spend $1200 to replace it, any suggestions thank you.
Old Nov 1, 2008 | 04:37 PM
cl600guy's Avatar
Default RE: my tandum pump needs replacing any help??
Ya check take the pump apart and check for a seal taht is broken. happened to another hydraulik part on my suspension. 600 for a part. but the seal was just 50 cents,.
Old Nov 2, 2008 | 07:12 AM
chassis221's Avatar
very difficult to do and very very messy, the nuts and bolts are very hard to access and you will need MB computer to properly flush and operate the suspension to remove air and possible dirt from the system, you also will need MB computer to see the system pressure when filling the tandem pump. it is not a job that you can do at home or even an independant for that matter. you will also need about 10 quarts of MB hydraulic fluid to replenish and purge the tandem pump then you will need to set the ride height with the MB computer. Take it to a dealer.
Kpassa
Feb 10, 2012 07:29 AM
JGHowland
Aug 5, 2010 08:13 PM
colorproz
Jan 25, 2007 02:21 AM
mersl500u
Oct 22, 2006 08:24 PM
xjvoorheesx
Jul 29, 2006 01:21 PM
