Wild idle
Old Apr 10, 2005 | 04:34 PM
BABAROGUE's Avatar
Default Wild idle
I have 96' C220 and occasionaly my idle goes wild but only when car is in drive and I have my foot on the brake pedal. It sits at 600 mostly, but for few seconds goes up and down to a grand, then 800 and so on back to 600 stable for a while. Car wants to go as this is happening but I step harder on brake pedal to control it. I wonder if this is a faulty idle motor if these cars have it and I wonder where is it located. By the way no codes which is truely wierd.
Old Apr 10, 2005 | 10:40 PM
sleepwalker's Avatar
Default RE: Wild idle
no vacuum leak?
Old Apr 11, 2005 | 04:47 PM
mikdade's Avatar
Intake air leaks can cause this and will not set off any codes. Inspect the intake air pipe and pay particular attention to the area AFTER the MAF sensor.
You can also spray some sort of starting fluid or equvalent around the intake manifold gasket and see if the engine RPM changes.
Old Apr 11, 2005 | 10:53 PM
BABAROGUE's Avatar
Wicked thinking. I'll test that. Thanks a million.
bungydiver
Mar 8, 2010 03:06 PM
everythingmercedes
Jan 23, 2009 03:07 PM
lcs164
Jan 23, 2007 11:27 PM
Lugnut
Aug 10, 2005 02:35 AM
rosenlou
Jul 29, 2005 03:08 PM
