Wheel Spacers
Old Jul 17, 2005 | 01:42 AM
Nicholas Winnie's Avatar
Default Wheel Spacers
Old Jul 17, 2005 | 02:18 AM
sleepwalker's Avatar
Default RE: Wheel Spacers
they have the same.
Old Jul 17, 2005 | 02:23 AM
we even rotate the wheels front to back every 10k km.
the spare wheel must fit front and rear too.
but on your model, you might have different set of bolts for spare.
Old Jul 17, 2005 | 09:44 PM
Old Jul 17, 2005 | 11:49 PM
i don't get what you mean of spacer.
you put it between the bolt and rim or between the rim and hub?
Old Jul 18, 2005 | 12:58 AM
SL600_Cruzin's Avatar
Yes, if you use a spacer you'll need longer lug bolts.
ie.. if the spacer is 5/16 you'll need lug bolts 5/16 longer than the ones you have.
Personally I can't stand to run spacers on the front-end as they can cause front-end vibration etc...
As far as wheel offsets go...... it sounds like you may have the wrong rims for your car.
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly.
hope this helps
Old Jul 27, 2005 | 05:48 PM
B Spoke
Oct 15, 2009 06:50 PM
rhbelter
Jun 28, 2009 08:59 AM
rsquad911Rsquad911
Apr 19, 2009 09:56 PM
jayagha
Sep 20, 2006 03:34 PM
cam69ss
Nov 15, 2004 04:35 PM
