What is a lambda sensor? where is it located on a '99 C280?
Old Feb 10, 2010 | 10:55 AM
Benz C280's Avatar
Default What is a lambda sensor? where is it located on a '99 C280?
I heard the lambda sensor could be the problem of many starting problems on a c280. Also can cause hesitation, poor idling and so much more.
Where is the lambda sensor located? is it the same thing as oxygen sensor?
your help will help many others.
thanks
Old Feb 10, 2010 | 03:30 PM
MB-TECH-38's Avatar
Benz C280,
i have not heard of a lamda sensor, they may be talking about an Air Mass Meter / Mass Airflow Sensor this can make a Benz do all kind of goofy things.
an O2 Sensor will not do all these goofy things anyway.
Old Mar 5, 2010 | 06:22 PM
LuvMyTJ's Avatar
Yes, there is such a thing as a lambda sensor, or an EGO.
<snip>The exhaust gas oxygen sensor (EGO or O2), or lambda sensor, is the key sensor in the engine fuel control feedback loop. The computer uses the O2 sensor’s input to balance the fuel mixture, leaning the mixture when the sensor reads rich and enriching the mixture when the sensor reads lean.<snip>
http://www.picoauto.com/applications/lambda-sensor.html
tonyleach8162
Jul 3, 2011 01:08 PM
ionutttt
Jun 21, 2011 02:31 PM
seblani
May 19, 2008 09:54 PM
loredan
Jul 31, 2007 07:21 PM
joeoregon
Oct 25, 2006 12:25 AM
