W205 Turbo issues
Old Jan 23, 2023 | 07:41 AM
tuga's Avatar
Default W205 Turbo issues
Hello everyone,
My 2016 w205 seems to have a turbo issue as under harder acceleration it loses some power and I have to let off the gas and then accelerate slower to get it to go properly. I find it happens mostly under hard acceleration merging onto the highway or while passing others. It has never gone into limp mode but maybe because I keep letting off the gas when it happens.
I put the scanner on it and I get the P029921 code "The boost pressure of the turbocharger 1 is too low. The signal amplitude is less than the minimum amplitude".
I have read lots about turbo hose leaks, diverter valves going bad, wastegate actuator stuck, etc as being the most likely culprits, but given that I can still drive the car normally and only under hard acceleration I'm experiencing the turbo loss, is there somewhere/or some item that I should be starting with (more likely to be the issue) when I'm starting to attempt to repair this issue?
Thanks in advance for any help.
Old Feb 15, 2023 | 03:10 AM
krystianj's Avatar
Did you resolve your problem. I have similar situation.
Regards
Old Feb 15, 2023 | 05:03 AM
NathanPeebody's Avatar
Same here. I am tired of the W205 Turbo issue and I am trying to find a proper solution online so that I can rid of this issue forever. I hope someone will reply to my answer. I am waiting for your reply and till then I will read reviews on this Twitter https://twitter.com/papers_owl_com link on papersowl. I want to hire an essay writer because I got a lot of essay assignments and I can't complete them in the given time on my own.
Old Apr 25, 2023 | 04:42 PM
Relatedatom's Avatar
Did you figure it out? I can't pass smog please help
Old Aug 26, 2023 | 03:18 AM
Snj's Avatar
Snj
Did you manage to get a solution to the problem tuga? I am currently experiencing the same issues.
Old Apr 15, 2024 | 10:59 AM
Shibs's Avatar
Originally Posted by tuga
Hello everyone,
I have a similar issue I changed the diverted valve the error went away but I still get no boost especially in steep hills the car won't boost. Anyone figured out what the issue might be. I have a 2015 c180 w205
Old May 1, 2024 | 02:53 PM
Sarakonor's Avatar
With a commitment to excellence and customer satisfaction, we ensure every project is delivered on time and to your specifications. Experience the difference with and take your communication to new heights. Elevate your written communication with writing services https://essayshark.com/ . Our team of skilled writers combines expertise with creativity to deliver top-notch content tailored to your unique needs. Whether you're a student, professional, or business owner, we offer comprehensive writing solutions that surpass expectations. From academic essays to compelling web copy, we specialize in crafting engaging, polished content that captures attention and drives results.
matthmal
May 22, 2022 04:26 PM
Geirh
Apr 18, 2022 06:24 AM
landrthegreat
Aug 23, 2019 09:33 AM
asheq_22
Oct 14, 2011 08:57 PM
