w203 Comand/ or LCD DVD
Does anyone here have the comand Center put into their w203, because all the ones available for my car are directly from Europe, so I dont know if they will work on the US version of the benz!!!
Also, does anyone know if the regular Double DIN LCD DVD players will fit in the dash (f.e. Kenwood, ALPINE, JVC) ?????
RE: w203 Comand/ or LCD DVD
If you have a pre 2005 C-class (W203, W202), you will be able to get a Euro spec comand installed. It will work with the US navigation discs without a single problem. The only thing you have to keep in mind, is that the Euro units use different AM frequencies. You will still be able to listen to (most of) the AM stations, but you will have to enter them manually.
If you have a 2005+ W203 C-class, you will NOT be able to use navigation when installing a W203 Euro spec DVD comand. These units will NOT work with the NA nav.DVD.
greetingz,
BigSis
greetingz,
BigSis
