W203 Airconditioning Problem
Old Feb 15, 2007 | 12:37 AM
sv4's Avatar
sv4
Default W203 Airconditioning Problem
I have a problem with the AC in my C230K that has left my regular independent mechanic stumped. On first start in the morning ( or after leaving the car parked for 5-6 hours ), the AC will only start blowing cold air after 6-10 minutes although the fan starts immediately. Previously, the cool air would come on fairly quickly, at least within a minute of turning on the AC. Once the cool air comes on, though, the AC performs very well. The AC would then also blow cool air almost immediately after short periods of stopping/restarting the car.
Full check on the airconditioning system revealed no leaks and refrigerant remains fully charged. Winstar diagnostics revealed a faulty evaporator temperature sensor which was promptly replaced. However,while further diagnostics revealed no more faults, the proble, persists. I would appreciate any suggestions, thanks.[/align]
Old Jun 7, 2007 | 01:38 AM
prima3443's Avatar
Default RE: W203 Airconditioning Problem
You are talking about the evaporator temperature sensor which one is it and where does it go?
Well because I have 2002 Mercedes C240 and have a heater problem, where when whatever I do it just blows hot air, even when I switch the temperature to cold IV tried everything. But if someone had this problem or knows about this problem please HELP!
Sincerely: Tony [sm=thanx.gif]
mbgt
Mar 31, 2009 06:20 PM
ceedi
Jan 19, 2009 06:06 AM
Cire
Jul 31, 2007 11:26 PM
sv4
Feb 15, 2007 12:37 AM
juanpablo
Dec 28, 2006 06:15 PM
