Unable to Fill up 99 C230K Gas Tank
Hi!
I've a 99 C230K w/ 167,000 miles. Recently, the car simply won't accept gasoline into the tank.
I can add approx 1 U.S. Gallon and that's about.
The fuel will blow back out the filler neck drenching the overflow tube and of course the person pumping the gas.
I have no codes showing on my OBDII reader, have disassembled the filler neck to the gas tank and have not found any think.
Is there a purge or pressure valve somewhere in the system that would cause this?
Thanks,
Ed
Thanks,
Ed
RE: Unable to Fill up 99 C230K Gas Tank
This seems to be a fairly common issue. Here is a previous thread:
https://mercedesforum.com/m_51035/tm.htm
Hope the link works. If not, do a search "Gas fill"
raklovits
04-04-2013 11:07 AM
