TPS W203:Failing ,Testing,Repairing
TPS: FAILING SYMPTOMS,TESTING,REPAIRING(the most)
Carried out on a w203 early model 06/2000(M111) TPS, with kickdown switch, 20k miles on. Probably applies to later's aswell, as other engines(M112,..),which use "hall effect" TPS sensors.
Applies to those members,who can't afford, or they don't want to pay high bills in MB dealers,and have some DIY skills. All others who can afford it, they haven't to worry,bother themselves,or spend time,
...,just pay!
SYMPTOMS:
1)Engine starts ok,idle ok.
2)Any time you press accel./pedal(..driving,or swifting gears,or idling ),no instant power,but comes after 3-5 secs delay , and ends in a limp mode or reduced power.(no kompressor boost/where available).
3)If you press slowly pedal,things are going little better,but ends with same undriveble way.
4)Once in a while or so,car may work perfect!!
This is the situation ,you have to reach,before proceed a TPS test.All others, who notice a rare power delay/loss,and after restarting the problem has gone ,they have the time . Soon or later will notice same symptoms, as TPS voltage setup fails.
ERROR CODES:
Some cases, put the correct TPS codes P0120,P0121.., other instead (many cases in the forums,aswell as mine) ,give MAF error codes,P0100,P0101,missfiring codes P0300,..thus driving to MAF replace (I try this also).There is an exlanation for it.(optional issue)
No matter if you erase the codes from the memo,after some driving circles,codes reoccur as stored or pending errors, in moderate revs.
So,in this point always proceed an unpluged MAF test.If the problem remain, replug your MAF ,it is OK,and proceed a TPS test, is the most suspicious.
TOOLS:
1) A reliable voltmeter/multimeter
2) A household battery supply of 5v,( or more volts, if using a variable resistor).
The target is: to obtain a testing voltage from the battery equals to the measurement w'll get later from theECU/ECM (N3/10 ME-SFI) voltage supply ,to TPS connector.(You can achive this using some old 1.5v,4.5v batts & doing compinations).The correct is, to use a variable resistor-is cheap.This is important to obtain accurate measures,from TPS Sensor later.
3) Two pieces of Φ:1,5mm wire, 1/2 meter long.
4) Two needles(pins),to put firmly in multimeter's leads with tape, to reach connector's narrow pins.
PROCEDURE:
1) Remove keys
2) Remove TPS assembly,as follow:
a)remove tap in the pedal base to see the holding nut.Undo nut,and raise a bit the pedal to give room.
b)Unplug beneath pedal the kickdown switch(k/S) connector.Use your fingers, or a bended long iron nail (not anything steel/scr-driver!!) , and a mirror to see what you doing,(if K/S,exists-till 4/2002).
c)Unplug the TPS 6pin connector in the right side,now you are ready to get the sensor off.
d)By moving it left/right(to avoid vertical plastic) and pulling towards you,and then turning upwards, you take it out in the bench.It is easy.But if you find difficulty,release plastic panel (3torxs) to make some
room,taking care to bonnet release **** & diagnostic socket (LHD)].
WARNING:
Before work on any electronic device's connector pins,always degauss your self,by touching a good ground (house water tubes..),to prevent static sparks,are lethal it.
N3/10 ME-SFI(ECU), OUTPUT VOLTAGE TEST TO TPS:
For this test,turn ignition on(cluster lamps on/II keys position),after finish take keys out.
In the unpluged TPS connector in the MBfloor,measure voltages at pins 1(+) & 6(ground),then at 1(+) & 3(ground)..These has to be between (4.75v-5.25v) limit.If so, this says that grounds is ok in ECU, and
Signals 1&2 (S1)&(S2), of sensor is supplied with correct votage.Now NOTE voltage (e.g 5.010v).This volt value have to be achived in the test battery for accurate setup.We are ready now for TPS test. AVOID accidental short cirquits during measures. Do CAREFULLY, and everything will work.
TPS INFORMATION:
As i found out dealing with this problem,the sensor uses the "hall effect" principle in order to avoid rapid use wear, (in comparison with old type variable resistors sensors),by no friction between moving parts.This is true for 1/3,2/3,3/3 sensor's positions,but not in the idle position.And i guess this is the weak point of TPS.After so many times of pressing and releasing the pedal,as time goes by (mostly from sudden releases),the pedal & sensor has to return back to its stop rather vigorusly, (with help from a rather hard returning spring),driving this to change its original stop position ,resulting TPS's idle voltage setup, out of calibration.Then all above symptoms occurs. With this in mind,i gave the follow easy
solution, (no TPS dismalting required).
PRE-REPAIR TPS TESTS:
Hold STEADY the TPS in the bench, (use carpender's catcher tool or so..) .
TPS VOLTAGE TEST:
Prepair the test battery with the CORRECT " previous noted" voltage of ECU output measure, (e.g 5,010v),and bring it near TPS.This voltage ECU is recognised, as a volt refering value for setups.
Take one piece of wire, and bare one side for connection to batt.(+) ,cut the other side clearly, and insert a needle to make a room, prior to insert it down with care, to male pin(1) of TPS connector.This is the (+) TPS feed for test.You don't have to move it again, before test is completed.
Take the other wire ,bare one end for connection to batt (-),the other end bare it about 3mm and twist it firmly then bend it back, and make a needle room, prior to insert it in male pin(3) , of connector.This is (-) feeding for S2 (low signal),& S1 (high signal) soon after.
To measure S2 signal,just put voltometers leads to touch, 3mm bare twisted wire in pin(3) (black lead), and the (red lead) in pin(4), the value you get is idle S2 signal,and have to be over 0,100v (in faulty TPS goes around 0,050v-0,080v). Rememper always to make S2 signal test first, because S2 gets lower faulty values, than S1 do. AVOID accidental s/c!
To measure S1 signal just remove the 3mm bare wire from pin(3) to pin(6), and measure value between pin(6)(black lead) and pin(5)(red lead),the value is the idle S1 signal, and have to be over 0,200v,
(in faulty TPS goes around 0,150v-0,170v).
THESE LOW VOLT IDLE MEASURES ARE THE CAUSE ,THAT PRODUCE POWER DELAY/LOSS BY GIVING WRONG SETUP INFORMATION TO ECU.
You can check also S1 & S2 volt values, at 1/3,2/3,3/3 & K/S positions (highest volt value). Maximum voltage have to be <4,990v ,but i'm guess you'll find all ok. Also check, that S1 values are approx. double than S2 are,in each pedal position measure. (Ignore pin2).
TPS REPAIRING:
WHAT WE TRY to achive by following trick,are: a) To get a S2 value at idle position, around ( 0,140v min - 0,180v max ),thus the S1 values will give somehow (0,320v - 0,380v max ) .
You 'll notise that daviation (dV) in S1,S2 signals, is over 8% than specification give, (actually is up to 13% approx),but ignore it,nothing you can do. No big problem . Mine reach over 32% , and no error code putted.In volt setup for ECU,is far important (hi-lo) S1,S2 idle volt limits,than the daviation}.The equation is dV% = (S1/S2x2-1)x100. Any way don't over pass maximums,because idle 'll rev to 1500 rpm .
b) To make a good feel, timelast pedal stop.
THE TRICK:
Is simple ,raise the TPS cover by unclicking side clicks & remove it.
Insert (not permanently) two plastic pieces of PVC (3,0-3,2mm panel's thick) till to TPS surface (for free TPS cover close), in the corners at inner sides of TPS ,where the pedal rest and leaves an approx. 3mm-4mm gaps (L-R gaps are not symmetric),(diagramm to be attached,red arrows).
The starting dimensions of plastic pieces, are approx.: LEFT SIDE 5,2X20,0 mm ,RIGHT SIDE 4,2X9,0 mm(no much room for longer insert).
Proceed now in TPS volt testing as described above,and do any changes to PVC width (using a grin-
der),prior to obtain desirable S2 value(0,140v-0,180vmax).Then check S1 value. If all are OK,go to
next final step.
FINAL STEP-WARNINGS:
A)The PVC pieces must have nice square cuts ,be CLEAN,and seat well in CLEAN TPS corners.
B)The moving pedal's stop,has to touch both PVC pieces simultaneously ,when returns.
C)At final stage,these pieces has to be SECURE for falling down,to AVOID troubles.
After glouing (i use UHU universal,is more elastic) , put a TAILORED STEEL CLIP for chassis holds,to secure for sure the pieces with TPS walls,and use a hair drier for awhile to dry glou,prior to put a second overlay .During heating, force pedal backward to make a good stop seat easier, between PVC pieces & pedal's stop.
AVOID glou, to stop points. AVOID/PROTECT sensor's overheating.
D)Use quality materials and your skill, to make a quality job.
E)The pedal must move freely to it's travel.After all leave it for some hours to dry,and..
F)Read well all above,and if you think your skills are not enough,DON'T do.
As a final touch, before close TPS cover,lubricate with silicone ,the two plastic axles of pedal motion.
Now recheck pedal's free travel,and feel how good it stops ,instead of previous slugish one,(it'll last long more , than it's original fiting).
Put TPS back ,in reverse action, make a TPS RESETTING ,(NOT by disconnecting battery ), and go for a ride to teach your ECU.The car will kill,costless, with 2-3 hours laybour.
GOOD LUCK
GUS
Any suggestion,comments,... are wellcome.-
Diagramm's Link:http://i594.photobucket.com/albums/t...TPSINSERTS.jpg
...,just pay!
SYMPTOMS:
ERROR CODES:
TOOLS:
PROCEDURE:
1) Remove keys
WARNING:
TPS INFORMATION:
TPS VOLTAGE TEST:
TPS REPAIRING:
THE TRICK:
next final step.
GOOD LUCK
GUS
goldlifter
Sep 6, 2006 06:35 PM
