TPS Help!!!!
Old Apr 16, 2008 | 08:34 PM
deadwards7's Avatar
Default TPS Help!!!!
So today my 2003 C240 became sluggish. I had just filled up my tank, and as i pressed the accelarator, my car would go about 1mph. I turned it off, turned it back on, and the check engine light came on--but the car drove ok then. I took it by an Advance Auto Parts and they ran the computer checker thingy. They got a code of P0121 which means it's the Throttle Position Sensor.
My question is:
How expensive is this sensor? How difficult would it be to replace myself? If difficult, how much will it be to replace?
Any suggestions/help would be GREATLY appreciated!!!
THANKS!!!
Old Apr 26, 2008 | 12:20 AM
Rico's Avatar
Default RE: TPS Help!!!!
Is the check engine light still on? When you did that startup after filling up, the computers didn't boot up properly -who knows why. The next time you started it corrected itself. The point is, after several normal start and stop cycles the check engine light will eventually turn itself off. I would'nt put much stock in the code either unless you get it several times. You could have a slightly weak battery.If it's an original battery, check to see if you can add water to it.
gusvlachos
May 25, 2009 05:47 AM
siliko
Apr 12, 2008 06:51 PM
deadwards7
Apr 2, 2008 05:16 PM
w_white
Aug 30, 2006 09:02 AM
legenesepimp
Nov 4, 2005 01:36 PM
