Serpintine belt replacement
Old Jul 28, 2007 | 03:50 PM
terryellis's Avatar
Default Serpintine belt replacement
Hello all,
I have a 2002 c240 and need to change the Serpintine belt. Is there a special tool needed for this?
Old Jul 28, 2007 | 09:03 PM
MasterBenzTech's Avatar
Default RE: Serpintine belt replacement
there are 3 thing you need. a 17mm deep socket, 10torx, and a ratchet. look for the belt tensioner. on the under side there should be a spot for a 17mm socket. then you just turn the belt tensioner to clockwise and remove the old belt. PAY CLOSE ATTENTION TO THE ROUTING OF THE BELT. then just put the new belt on.
if there is no room/spot for the 17, then you need to use the torx on the front of the pulley.
PelicanParts.com
Jun 25, 2013 11:45 AM
rogerc
Aug 30, 2011 04:40 PM
PortalanzaMD
May 17, 2010 01:54 PM
BIG JOE 40
Jan 26, 2009 07:38 PM
Benz_190
Aug 26, 2005 01:15 AM
