rim size
well i just wanted to buy some specific rims, but that's the only size they carry that are 18s. i searched and i see that some people have those exact measurements on their car, but i'm not too sure if it's alright. i'm going to lower the car as well. 1.75 rear and 1.50 in the front. will those work? or should i try something else? what do you recommend?
As long as the wheel offset is in the 35mm range, you should not have any problems running those wheels, or even lowering with that size. When I went to 18s, it was slightly a rougher ride, but I'd much rather have the wheels than the perfectly smooth ride!
#10
offset between 31-40
no wider than 8.5 in the front and 10 rear
tire size no wider than 235 front and 265 rear
its easier if you post your size so we can tell you specificly, im not promising anything with the above specs, its a loose estimate
DPMoney
01-18-2007 02:43 PM
