remove door cover/lining
Old Oct 12, 2005 | 10:53 PM
Si's Avatar
Si
Default remove door cover/lining
Hey guys, Can anybody tell me how to remove the drivers side door cover/lining off a 94 C280?
I've got any annoying rattle coming from inside the door. :-\
Thanks in advance
Old Oct 13, 2005 | 12:50 AM
C280's Avatar
Default RE: remove door cover/lining
http://202tech.mkosonen.com/howto/doorpanel.html
God dang im a helpful mo fo.
In return for such an awsome link post up a pic of something cool, maby even your car.
That is a very helpful site ^ im not sure who the owner is but he deserves respect
Old Oct 14, 2005 | 10:05 AM
C280 wizard's Avatar
ORIGINAL: C280
GREAT site for us W202 owners, C280 do you know how to remove the knee pad on the drivers side? I removed the bottom cover but couldn't figure out how the knee pad is removed. I want to install DRL module and it is a lot easier to do with the knee pad off.
Thanks!!!
Old Oct 14, 2005 | 08:32 PM
C280's Avatar
Whats a knee pad? im not with you here and DRL???
Old Oct 15, 2005 | 10:50 PM
The pad at the bottom of the dash, or the pad the steering column disappears into. the Knee Pad Bar Mercedes calls it. DRL Daylight running lights, it is a change to a differenece module, at position N35 which is under the dash right of the light switch, but the connector is behind the Knee bar. US cars don't come with them standard, but from the information I have gathered from the schematic the connector is there. To make the job easier the knee pad needs to be removed. Mercedes makes it hard. I had a BMW all that had to be done was to change the standard headlight module for th DRL. which was under the dash but easy to reach. Reason I want DRL's in Mass you get an extra 10% discount on your insurance. When you turn the key on the headlights light up, but not as bright, when you turn on the switch they revert to normal brightness. Also, I found the headlight units have the opening for the city lights, required in Europe, these are used in the city and the DRL's are shut off. I had the city light hooked up, but to the parking lights, in Europe the highlight switch is different, and has extra setting for DRL's, city lights headligts, fog light, and those left and right parking lights.
Old Oct 17, 2005 | 01:17 AM
RockSolid's Avatar
(That does look like a helpful site. Bookmarked it right away.)
Are you sure the rattle is in the door and not the B-pillar? I thought for the longest time that a rattle was coming from the door and it turned out to be a loose metal clip for some plastic molding on the B-pillar. All it took to fix was a firm pressing on the outside of the trim.
Old Nov 2, 2005 | 12:26 AM
Si's Avatar
Si
Thanks Guys!!!!!!!!!
I tried pressing on the pillar and it stops! However it starts again after i let go, ive tried pushing the cover in but its doesnt stop the noise :-( Ill see if i can work out how to remove the pillar cover and take a gander :-)
Old Nov 2, 2005 | 07:35 AM
C280's Avatar
piller cover you need to pull back the rubbery door surround thing then there is steel clips under it
Old Oct 15, 2007 | 11:17 AM
  #9
dlance2's Avatar
Good advice. I see the clips, then what?
Thanks in advance for the help.
car5car
Aug 22, 2011 09:17 PM
holen1
Jun 18, 2007 06:56 PM
Xacting
Nov 10, 2006 01:30 PM
arivlin
May 9, 2005 02:57 AM
vlad
Jan 14, 2005 10:32 PM
