Is the rear trunk c230 & kompressor badge glued or Mechanical applied ?
Old Mar 24, 2008 | 09:10 PM
tropics's Avatar
Default Is the rear trunk c230 & kompressor badge glued or Mechanical applied ?
I want to take off the C230 and Kompressor badges but are they glued or mechanical applied?
Old Mar 24, 2008 | 09:14 PM
tropics's Avatar
Default RE: Is the rear trunk c230 & kompressor badge glued or Mechanical applied ?
2004 Sedan sport
Old Mar 24, 2008 | 11:20 PM
DoubleNickle's Avatar
glue.... dealership can take them off for you..or a body shop....if you wanna do it yourself be careful of the clear coat....Desolvit Contractors solvent works great! why do you wanna get rid of them?
Old Mar 24, 2008 | 11:22 PM
mrcoyote's Avatar
I just looked at mine and it seems they are glued or stuck on with double-sided stuff they use on a lot of cars
for emblems. Definitely not mechanically attached with bolts or anything. I see people that have taken theirs off
and there are no holes. Sometimes a hair dryer can help, but you've got to be really careful you don't goof up the
paint with too much heat. I use a plastic stick and a hair dryer. A heat gun is too hot. Go slowly.
Old Mar 25, 2008 | 02:37 PM
Defiant's Avatar
Park in the sun to get it warm, and use fishing line to "saw" the foam rubber. Many sites online will show how to do it, and there are videos on You Tube. Then, a solvent such as Goof-Off to remove the remaining adhesive.
Old Mar 30, 2008 | 08:34 PM
tropics's Avatar
Thanks all great information...I will be taken them off soon. Thanks again
Old Mar 30, 2008 | 08:36 PM
C280 SPORT's Avatar
Are you looking to rebadge the car?
Rusty Westgate
May 17, 2015 01:17 AM
Tont-1951
Feb 12, 2012 07:16 AM
sokxmania
Apr 25, 2011 01:12 AM
firstfeather
Mar 25, 2008 04:11 PM
1996_S500
Jul 13, 2006 02:59 AM
