Radio speed volume Control
Old Feb 25, 2006 | 09:18 PM
osheatwo's Avatar
Default Radio speed volume Control
I just brought a 04 C230 and was wondering if there is a way to adjust the speed volume control on the radio
Old Feb 25, 2006 | 10:34 PM
sleepwalker's Avatar
Default RE: Radio speed volume Control
it automatically adjust itself. when you go to a higher speed, the radio turns up the volume...does it?
Old Feb 25, 2006 | 11:08 PM
Rainman15's Avatar
ORIGINAL: osheatwo
I've asked my dealer about it and they claim it is not adjustable. I personally find this one of the most useless and annoying features put on a car. The only way I can think of to do away with it is to change the stereo completely with an aftermarket unit.
Old Feb 25, 2006 | 11:10 PM
osheatwo's Avatar
Yes that is true but am asking how do you change the setting to control how much it will adjust. Right now the setting is too high so at highways speeds i have to turn dowm the volume so the sound does not sound distorted. I had an Audi and you could access those special settings and and change it from 1 (low) effect to 5 (high) effect. Wondering if there was a way to enter those backdoor settings on the radio for my 04 c230 non bose radio, thanks.
Old Feb 25, 2006 | 11:22 PM
Rainman15's Avatar
I realize your question, but the only answer is it isn't adjustable. It is preset in the radio when it is built.
Old Feb 25, 2006 | 11:33 PM
quite easy.
there is one blue wire on the radio connector which gives signal to turn the volume up.
cut it.
if you need diagram, state your VIN.
Old Feb 26, 2006 | 01:45 AM
C280 wizard's Avatar
My Bose system the radio volume lowers when the speed of the cars slows, and vice versa. I had a Bimmer with this feature, but you could adjust it by entering and code and you had three choice as I remember volume increase low, med and high. But my C280 does increase and decrease on its on? A Fluke or is this standard also? Also, my radio really doesn't increase volume until the car gets to 60mph. It also when shut off and the engine is shut off the volume control returns to the volume I had it set on previously when I turned it on.
Old Feb 27, 2006 | 07:56 PM
Mixxed's Avatar
ORIGINAL: sleepwalker
quite easy.
cut it.
But doesn't that data line also cut your communication between the stereo and car for other things too? I had the same problem and I asked a Crutchfield tech... he researched and found that the same data wire that controls the volume control also tells the radio to shut off when the ignition is turned off, so he suggested not cutting it.
True?
I wanted this option off because I added a 10" subwoofer to my car, and the volume control sporadically goes CRAZY because I'm guessing it picks up the low frequency bass and interprets it as "noise', so it goes up and down like crazy sometimes... and it's REALLY annoying.
Old Feb 27, 2006 | 11:29 PM
  #9
it depends on radio model.
yours could be using MOST system.
Old Feb 28, 2006 | 11:36 AM
  #10
RockSolid's Avatar
C280 wizard, do you find the automatic volume control in your Bose system anoying? I believe i have the similar system and I think it works well. In my other car, I have a automatic volume control which I can set, and I've never found a setting that I like as well as the built in one in my C280's Bose system.
jaustill
Sep 16, 2011 05:24 PM
C280 SPORT
Nov 26, 2007 08:45 PM
C280 SPORT
Nov 24, 2007 11:05 PM
E430
Nov 17, 2007 10:24 PM
E430
Oct 15, 2007 11:50 PM
