Problem with locking system
Old Oct 28, 2011 | 12:37 AM
Minsring's Avatar
Default Problem with locking system
I have a problem locking my car using a remote control. I can only lock/unlock the driver sided with the remote, but the rest remain unlock. I have to manually push the lock ***** down to be able to lock my whole car. Also, my gas lid would not open sometimes.
Can anyone help me? I don't know what is wrong with my car. My car is 2000 C280.
Thank you in advance!!
Old Oct 28, 2011 | 09:57 PM
chassis221's Avatar
check all fuses first.
Old Oct 29, 2011 | 03:36 AM
Minsring's Avatar
I did checked all the fuses...it is fine.
Old Oct 29, 2011 | 09:43 AM
chassis221's Avatar
if your sure the fuses are fine, then now check your door jam switches, on the affected doors.
even when you use the interior switch, only the driver door works? if those are all fine, you could have a vacuum leak someplace. i still suspect a relay or fuse.check fuses in the trunk in front of the spare tire, there are some fuses there too.
Old Oct 30, 2011 | 12:31 PM
Minsring's Avatar
Ok I will do that
Thank you.
Old Nov 2, 2011 | 09:36 AM
Unimog_01's Avatar
Default Ignition Tumbler
Can you help me out with my Lock issue? C220 1996
I have to replace my Tumbler( Key wont turn at all. Ordered a new Key, still no luck)
does the lower Dash separate from the upper? I have everything loose but am afraid to damage the plastic, I cant make out how it is connected.
thanks
C220 1996
springglen6
May 10, 2015 12:29 PM
manirm
Aug 2, 2009 12:45 AM
delboy277
May 12, 2009 05:19 AM
c2201995
Dec 30, 2008 04:35 AM
fwillie
Oct 8, 2004 01:24 PM
