One touch Mirror Down not working
C240 2002
The driver window one touch mirror down function has stopped working. I have to press the switch all the time until glass is up or down. Earlier I use to just press it hardly once and it used to either close completely oropen completely.
Also If I had all the windows of car opened and I switch on the A/C I used to press in inner flow only option harder once and all windows use to close. Now only drivers window is left open and all close.
I want to know how can I fix it ? Can I fix it myself if I just buy some fried part from autozone ....
Please help ... this is getting really irritated for me![Frown](https://mercedesforum.com/forum/images/smilies/frown.gif)
Sounds like a possible problem with the dcm door control module in the driver door. It has to be programmed by the dealer. Did you try to re-syncronize the window by holding it all the way up for a few seconds? Most common is that the window switch unit fails, commonly the driver window due to the most usage.
patricknif
03-04-2012 06:38 AM
