OEM parts vs. genuine parts?
Old May 25, 2008 | 02:27 AM
hughits's Avatar
Default OEM parts vs. genuine parts?
Hi fellas,
Do OEM parts work fine? Any worries or concerns to use them?
I need to buy spark plugs and wire, crankshaft position sensor, and a few. I am wondering if I can use them. Genuine parts are terribly expensive, aren't they?
Thanks for your help in advance.
Hugh
Old May 25, 2008 | 11:48 AM
will3hawks's Avatar
Default RE: OEM parts vs. genuine parts?
As for spark plugs, Mercedes recommends Bosch and NGK- either are a good pick though from what I have seen lately, many people think that NGK is the better plug.
Regarding ignition wires, unless you are sharp with electronics i'd stay with OEM or Bosch.
The issue is that you can end up spending more by buying cheaper parts and having them not work or wearing out sooner if you are not careful. Remember that one of the curses of a global economy is that parts sourced even from The Fatherland may have been made in India or some other 3rd world ****hole and be vastly inferior. I have a friend who bought a bumper from an American company for his Jeep. Within 2 years the entire outside surface had rusted. When he pulled it off to replace, he found the made in china stamp in one of the corners.
I would definitely buy the CPS from Mercedes.
Regards,
Will
Old May 26, 2008 | 07:38 PM
2fast4u_c280's Avatar
sometimes and depends on part aftermarket are better then oem.
Old May 27, 2008 | 11:06 AM
hughits's Avatar
Thanks guys. I think I can use Bosch for ignition stuff then. Yes, I will try to get genuine CPS.
PelicanParts.com
Oct 1, 2013 12:09 PM
PelicanParts.com
May 22, 2013 07:08 PM
RLLanham
Mar 2, 2006 04:57 PM
BlackWolf
Jan 26, 2006 12:17 PM
paQ
Apr 11, 2005 07:54 PM
