noise in window
Old Dec 20, 2010 | 01:01 PM
Damon's Avatar
Default noise in window
just bought a c class 203 and i noticed that when i put down the driver's side window there's a slight sort of crunching noise. it's very faint, in fact when the stereo is on you dont hear it, but when it's quite you can hear it sort of crackling, only when the window is going down not up. any idea what it might be please? the winder perhaps? should i repair it now, or should i let it get worse first?
Old Dec 21, 2010 | 12:22 PM
platonmind's Avatar
You need to remove outer sealing rail and clean it up from dust. Use dust remover spray and rubbing alcohol for rubber part. Before reinstalling outer sealing rail, run the window up and down a few times to check if there is any bad sound. Taking off outer sealing rail depend on model and it is tricky.
Old Dec 28, 2010 | 02:55 AM
Damon's Avatar
thanks platonmind, managed to remove the outer seal and did what you said with the dust remover spray, the noise didnt go away completely but it is much better now, hardly noticeable, thanks!
ifthecar
May 12, 2013 02:07 PM
Rockerfella174
Apr 20, 2008 09:52 PM
tcrofford03s55
Dec 19, 2006 09:45 PM
bburch88
Aug 10, 2003 12:44 AM
willeys
May 28, 2003 05:28 PM
