No radio reception & door remote works only when aimed to door handle.
Old Nov 4, 2011 | 07:59 PM
  #11
maldo04's Avatar
Default No radio reception & door remote doesntworks
Recetly I have this problem on my 2005 c230 k,Iget fuse 8 on backsam blow.Is continue blowing,i diconect the antena amp on the rear class but continue blowing the fuse.What else are conected to this fuse for disconect to check were are the short circuit or if some one have the wiring diagram to trace this circuit to found the problem.Also if some body know how to fix I will appreciate the help.
Old Nov 4, 2011 | 08:11 PM
  #12
chassis221's Avatar
ive had a car with the same issue..this was a hatchback C230 coupe, the wiring harness around the rear liftgate/trunk glass was chafing on some clips. youll need to remove the interior plastic trim around the rear window and look for where the wire harness is rubbing something.
Old Nov 5, 2011 | 09:26 AM
  #13
maldo04's Avatar
My is a coupe and don't see any damage on the wiring throw the post and the rear class, I will try to trace the wiring,but if some one know to were places this circuit goes I will appreciate the help.
Mrman
May 10, 2015 08:16 PM
Diesel99
Jun 26, 2007 09:01 AM
seraphim
Feb 2, 2007 04:17 PM
yorgasor
Jun 20, 2006 12:35 AM
sing23
Jun 9, 2006 09:22 PM
