need help with rear passenger wheel
Old May 3, 2008 | 09:46 PM
LONGBEACHc230's Avatar
Default need help with rear passenger wheel
hello everybody i have a 2002 c230 kompressor , one problem, my rear passenger wheel sound like the rotors is rubbing on the brake pad, and it somtimes get extremely loud like metal rubbing metal, took it to the auto mech. they said looks like nothing is wrong they told me...
wheel bearing : great condition
brake pads: just installed it 1 month ago
rotors: need to be re-finished, but not bad enough to cause any noise
and also said that the rotor is not rubbing agianst the cover behind the rotor
any1 have any idea what it can be please help, open to all suggestion thanks alot ppl!
Old May 4, 2008 | 05:32 PM
chassis221's Avatar
Default RE: need help with rear passenger wheel
Emergency brake rubbing,,,,adjusted to tight. you should be able to
spin tire when off the ground.
Old May 4, 2008 | 06:44 PM
how do i adjust the emergeny brakes?
Old May 4, 2008 | 07:09 PM
chassis221's Avatar
must remove rim and then you look threw the lug holes and look for a Star wheel turn it with a screw driver. each side is opposite, up is tighter brake and turning the star wheel down will loosen. when you push the ebrake it should generally go about half way to the floor. .....but if you turn the wheel while off the ground and you dont hear anything dragging or grabbing and the wheel spins free you prob ok then.
mick.anic
Apr 17, 2013 12:30 PM
wikkedpissa
May 14, 2012 07:04 AM
everythingmercedes
Oct 9, 2008 08:02 PM
avikanal
Jul 11, 2007 10:19 AM
avikanal
Jul 8, 2007 12:23 PM
