NEED HELP ABS, BAS, ESP Malfunction has been detected
Old Apr 27, 2006 | 06:04 AM
DGW203's Avatar
Default NEED HELP ABS, BAS, ESP Malfunction has been detected
This afternoon I show my car to the buyer that came down to take a look, test drove it and everything bought the car picking it up this sunday Five hours later while I was driving the message displayed one or more Malfunction BAS-Brake Assist Visit Workshop, ABS-Visit Workshop, And ESP- Not Available Whats going on? I shut the car off and restarted its was fine for ten min..or so The message displayed came back. Any Idea?? Should i unplug the battery? my car only has 44,000 miles its a 2001 C320 and the buyer is goin to pick up this coming Sunday HELP PLEASE!!!!!!!!!!!!!
Old Apr 27, 2006 | 06:46 PM
DGW203's Avatar
Default RE: NEED HELP ABS, BAS, ESP Malfunction has been detected
Checking the manual book With the ABS malfunctioning, the BAS and ESP are also switched off. Both malfunction indicatior lamps come on with the engine running.
If the charging voltage falls below 10 Volts, the malfunction indicator lamp comes on and the ABS is switched off. When the voltage is above this value again, the malfunction indicaor lamp should go out and the ABS is operational. So whats really goin on I have a brand new Battery replace few months ago should i unplug the battery?? Or you guys think its the Sensors still I really don't want to spend $$..
Old Apr 27, 2006 | 06:55 PM
Lugnut's Avatar
When all those brake-related lights come on at the same time, it usually turns out to be a defective brake light switch. It's under the dash and trips when you press the brake pedal. They're under $20 and usually called a stop light switch by the retailers. I'd try that first since it's a cheap and easy DIY fix, if it's the problem.
Old Apr 30, 2006 | 01:41 PM
benzpimp's Avatar
this happen to me on my '99 c230 my bas/asr light came on and the way i got rid of it was i went to the dealer i bought a brake pedal switch and i changed it my self and the light was gone. It took me 30 min. to change it.
Old Apr 21, 2016 | 02:32 PM
teri1996's Avatar
Default Finnaly found solution. This will work for all!. ABS ESP BAS Malfunction fault warnin
Check out this video!
DS
Aug 31, 2006 07:20 PM
DGW203
Apr 27, 2006 06:40 PM
BenzoDJ
Feb 26, 2006 12:02 AM
BenzoDJ
Feb 24, 2006 12:14 AM
manaiauds
Feb 19, 2006 12:55 PM
