Info on SAM module
when you replace a Sam module, they recommend that you replace both front and back Sam's, and to order the service kit, which is only a single wire factory made, to plug into two different connectors on the front Sam module. It connects from one connecter in #4 port to # 12 port on another, then both Sam's have to be reprogrammed, the wire is to make sure you don't have problems starting the vehicle because of the security system. Hope this helps
