Horn Problem
Old 02-21-2007 | 09:26 PM
benzpimp's Avatar
Default Horn Problem
My horn just recently went out and i would like to replace it or know if anyone has had the same problem and has fixed it. I'm a DIY guy so any challenge is up my ally.
[align=center] [/align]
Old 02-21-2007 | 11:47 PM
benzdean's Avatar
Default RE: Horn Problem
hahaha, same here. I usually replace parts myself and just ask a help from my friend whenever I need a part to be replaced on my old c230.
try to google for online parts store. I suggest you should shop on those sites that Ive come across with and been satisfied with their products. try: www.benzbin.com or better, www.mbpartswarehouse.com (good customer service) and www.mercedesshop.com (good customer service/technical info).
it's for your own exploration. as said last time, I can hardly suggest eBay. most of the sellers there are fakers, selling inferior parts that doesn't suffice the price and swindling money.
Old 02-25-2007 | 09:32 PM
benzpimp's Avatar
how do you replace the horn. and is there any way of checking to see if its even broken before i buy a new one.
Old 02-26-2007 | 11:07 AM
Shan's Avatar
Disconnect the existing wires to the horn. make direct connection from the battery.If the horn does not sound, then it needs to be replaced.
If it sounds, then check the horn relay for fault.
Shan.
Old 03-06-2007 | 04:40 PM
Mercedes Benz of FL's Avatar
Replacement is real easy.
Just remove the old busted up horn.
take it to Pep Boys, Autozone, Discount Auto Parts or any other after market dealer and they will replace it.
Get a good reliable one with high decibels.
It really is that easy.
Remove wires from back of horn
Unbolt horn
Go shopping for a new horn
Replacing it;
hook wires up to new horn FIRST
TEST the new horn
See if it blows
If it works, then disconnect wires from new horn
Install new horn
Reconnect wires
Pat yourself on your back for a job well done
Old 03-08-2007 | 08:00 PM
bluebirdnips's Avatar
easy if you know where it is, took me ages to find mine up under the wheel arch cover on the offside front wheel. sorry c180 model
Old 03-09-2007 | 04:28 AM
benzpimp's Avatar
thank you Mercedes Benz of FL i did exactly what you said and i fixed it with a $15.99 horn from autozone.
Old 03-09-2007 | 01:28 PM
Your da' man! Awesome
that's One more for us DIY'ers!
( is that english? )
  #9
Old 04-10-2014 | 06:54 AM
Antoinette Faye's Avatar
Default Mercedes c220
Hullo all just want to thank the users for assisting me with the removal of the aircon fan and condenser, it is obvious that the condenser/regulator needs replacing as it is very corroded. This is due mostly because the unit is situated under the vent area which gets blocked by leaves etc and then rain leaks into the car over the aircon unit, stupid place to put it. Thank you also for indicating the position of the hooter/horn, which I have also replaced. Great to be able to google anything like this especially when you are a woman and you want to get things done yourself.
Ant
Rev Den
11-13-2012 02:32 PM
galad
03-22-2010 05:34 AM
firstlook
05-30-2009 04:48 PM
joecv1952
03-29-2009 11:57 AM
guypatterson56
11-30-2008 10:27 AM
