Hi, I'm new. Need help with 05 c230 Check engine light!
RE: Hi, I'm new. Need help with 05 c230 Check engine light!
My CEL came on a while back and it ended up being a crack in a wiring harness. The light was shorting out b/c oil was getting into the pins of the connections. I had to get it checked out at the MB dealership to tell me this. Ended up being quite expensive to fix, but they covered it under warrenty.
Only way I know to check a warning code is go in to a mechanic who has a cpu to hook it up to. Then they can tell you what's up.
Good luck
Good luck
Kikoap
07-30-2012 02:50 PM
Kikoap
03-27-2012 10:37 PM
Matz445
10-12-2006 05:39 PM
