Headrest problem
Old Nov 16, 2006 | 04:04 PM
C280 wizard's Avatar
Default Headrest problem
The powered headrest on my 99 C280 has a mind of its own. when I press the button on the door to either lift or lower it, it works and sometimes it doesn't. If I hit the seat a couple of times with my fist it will work. I have taken off the back seat panel and find there is something loose, it seems to be a connections to the motor. BUT I have no idea on how to tighten it. It is a plastic connector and if I push it into the blades the headrest works, but the circuit is broken as soon as I put the back cover on. I have checked for pinched or pulled wires. However, the problem seems to be at the connector.
I also noticed is I take the weight of of my shoulders off the back of the seat, sometimes the headrest will work?
The passenger side works fine.
Thanks!
Old Nov 16, 2006 | 04:42 PM
mbz300sdl's Avatar
Default RE: Headrest problem
Did u try cleaning the terminals on the connector?
Old Nov 16, 2006 | 08:28 PM
sleepwalker's Avatar
confirm first if it's mechanical (gear strip) or electrical (motor working or not).
559EVO
Jul 1, 2024 03:34 PM
cherylblodgett
Nov 30, 2009 10:11 PM
tuslac
May 12, 2006 01:02 PM
pc820
May 10, 2006 12:38 PM
hk91308
Aug 23, 2005 06:06 PM
