gauge issues
Old May 6, 2019 | 12:17 AM
Jeff Ingrum's Avatar
Default gauge issues
already replaced fuel senders booth fuel pump and every thing was fine for about a month. today fuled up and noticed gauge was still on empty with low fuel light on checked remaining miles on dash it says.........what could be this cause do i need to check fuses iam lost
Old May 6, 2019 | 02:21 PM
PelicanParts.com's Avatar
Hello and welcome to the forum Jeff- there are several possibilities. Take a look below to a couple of areas to look at for the possible issue:
One is a problem with the fuel sender unit. I doubt it's a stuck float, since there are two floats (because your fuel tank straddles the driveshaft) and the level is calculated by an algorithm that considers both readings. It could be a wiring issue, or a problem inside the sender unit (left side of tank), but again, it would mean both wires are a problem. Let us know if you have any other questions and if we can assist with any future part needs.
Nyko46
Jan 4, 2020 08:47 PM
Nyko46
Dec 15, 2019 08:06 PM
august240
Mar 10, 2012 08:04 AM
nickarya
Sep 19, 2007 06:36 AM
imran
Apr 19, 2004 06:21 PM
