Engine won't yurn over!
RE: Engine won't yurn over!
im assuming you mean it cranks but will not start? if so, check your fuel pressure and make sure you got any. theres a little valve on your fuel rail under your air cleaner box. open that valve, stick a small screwdriver in there and have someone crank the ignition from inside the car. some fuel should spray out. it will make a little bit of a mess but wont hurt anything. post up your results
digieditny
08-29-2010 04:59 PM
