Engine shuddering & no acceleration
Old Apr 13, 2006 | 09:17 AM
vlc_uk's Avatar
Default Engine shuddering & no acceleration
I've a C200 coupe 2002 the engine light is on. When the cars standing the entire engine shudders and when i pull away there is no acceleration even if my foot is flat to the ground. Its an automatic and it seems to rev up and struggle in the lower gears. I've had it at a merc approved garage and they replaced the chip on the top of the engine which controls the air flow? It's made no difference. Has anyone had the same problem or know what's causing it.?
Old Apr 13, 2006 | 10:02 AM
sleepwalker's Avatar
Default RE: Engine shuddering & no acceleration
if the engine shudders... then it must be misfiring.
if 1 or 2 cylinder misfires, there is no acceleration.
Old Apr 13, 2006 | 01:11 PM
area51's Avatar
I had an ignition coil go on mine. It had the same problems you are having.
m110cut
Nov 15, 2009 10:24 AM
blackedout300e
Apr 17, 2009 07:39 PM
burwellassoc
Jan 11, 2008 09:18 PM
E320WagonXTwo
Dec 12, 2007 12:59 AM
wagits
Dec 27, 2006 06:43 PM
