Elec probs
Old Jan 7, 2006 | 01:56 PM
MikeB's Avatar
Default Elec probs
Just found this forum and already solved a couple of probs I had. My battery was completely discharged and swapped out batteries. I got the windows to operate and the radio to function. I cant trace this prob though.....my turn sigs, e-flashers and windsheild wiper do not operate. I`ve checked all the fuses and they check OK. I`ve traced the system and of course the turn sigs and e flashers share a fuse and the windshield wiper system shares a common fuse, it seems to me that finding and replacing the fuses common to both systems would solve the prob....any help would be greatly appreciated. Thanks
Old Jan 8, 2006 | 04:44 AM
sleepwalker's Avatar
Default RE: Elec probs
welcome MikeB.
what year/model was your c-class?
Old Jan 8, 2006 | 12:29 PM
MikeB's Avatar
Its a 2000 C-230 Kompressor. Also upon further troubleshooting, I have found that the rear window defroster, the rear head rests button, horn does not work. I recently changed batts but my girlfriend said this problem was before. She also said that she drove the car in a storm and the horn was blowing and would not shut off and then when she started it the next day nothing worked. I have replaced all the fuses that have that circuit in common, its a 15A in the # 41 slot. Thanks for the reply
Old Jan 8, 2006 | 10:09 PM
MikeB, the only common thing i find is that they both use fuse #22.
please check it first then come back here if it's still not ok.
[IMG]local://upfiles/1/3042714C6364465FA8C0041726E718D2.jpg[/IMG]
[IMG]local://upfiles/1/1110FA05F9284013A2D94A89183E038B.jpg[/IMG]
[IMG]local://upfiles/1/5E263CF5A9F04BA88C6FE2134B662167.jpg[/IMG]
Old Jan 9, 2006 | 10:44 AM
MikeB's Avatar
Replaced the fuse with a new one and still have no power. Thanks for the drawings!!!! & the help
Old Jan 9, 2006 | 09:13 PM
MikeB's Avatar
Changed a relay I thought was bad also..still the same
Old Jan 9, 2006 | 10:32 PM
your N10/1 (SAM [signal acquisition module]) got problem.
remove and check if the water have penetrated it.
Old Jan 10, 2006 | 10:28 AM
MikeB's Avatar
Where is that located?? I`ve looked and cannot locate it. Again , thanks so much for your time
Old Jan 10, 2006 | 11:03 AM
  #9
MikeB's Avatar
Just looking at the drawings, correct me if I am wrong..the SAM is the entire fuse / relay box?? Can this be replaced without a dealer and does anyone have an idea what it costs?
Old Jan 10, 2006 | 12:02 PM
  #10
MikeB's Avatar
I pulled the fuse / relay box. Is the SAM the thin black box on the underside of the relay module?? Will removing this wipe everything else out that does work??
