Driver power seat does not work sometimes???
Old Dec 31, 2010 | 02:52 AM
maxier's Avatar
Arrow Driver power seat does not work sometimes???
At first everything works, but after I sit and drive for about 15 minutes, the forward and backward do not work, others positions work fine. It happens the same thing the next day. Any sugesstion would be appreciated. Thanks 96' C280
Old May 17, 2011 | 08:15 AM
John Hubertz's Avatar
Exclamation
I have this same problem. Help, please?
Old Dec 21, 2011 | 08:41 AM
Jewjenk's Avatar
Wow no one has answered this, I have the same problem, did a search -- nothing
Old Dec 21, 2011 | 03:37 PM
90vfradam's Avatar
My wifes car had a similiar problem. when the seat was moved it would pinch some wire under the seat.
Old Dec 21, 2011 | 06:27 PM
1729ers's Avatar
Default Seat adjustment doesn't function
I resolved this problem in my 1999 C230 by changing the seat adjustment relay located in the trunk of my car. I have read that that solder joints inside the relay crack and can be re soldered, but this only worked temporarily for me.
Old Dec 27, 2011 | 09:24 AM
Could you tell us please where this relay is located in the trunk?
Old Dec 28, 2011 | 10:02 AM
Ed_in_Va's Avatar
another possibility may be the seat switch - our 99 C230 did the same thing. Ended up replacing the switch in the door. (tried pulling it out & hitting it with electric connector cleaner - but that really didn't help) easy to replace in the door - took about 15min.
here's a source for your switch - if you choose to go that direction. (Car Part Wholesale - Auto Parts and Accessories Catalog - Seat Switch For 1996 Mercedes Benz C280 Base 6 Cyl 2.8L)
Cheers,
Ed
Old Dec 28, 2011 | 03:54 PM
1729ers's Avatar
The relay in my car is under a plastic panel which is in front of the space where the spare tire lies. The relay is on the passenger side of the car in my vehicle. Hope that helps.
Old Dec 29, 2011 | 01:50 PM
  #9
With this good information I did a search on "comfort relay" and got this additional info:
"Mercedes Benz 1998 C280 Relay part # is 002-542-22-19 this will fix your power seats from doing crazy stuff.
Example:
Working only in the morning, only works every now and then, with door open, key in or out. Purchase k24 relay and all your problems will go away. My Benz dealer charged me $42.90 for a new relay"
Anyway - looks like the mystery is solved. My thanks especially to 1729er for putting this thread onto the right track.
Jopenko1
Dec 10, 2012 03:18 PM
brudd
May 9, 2010 01:15 PM
widmer
Oct 19, 2007 03:14 PM
bookerzisme
Jan 12, 2006 08:43 PM
dgboggs
Dec 9, 2005 09:58 PM
