Crank Position Sensor
Old Aug 7, 2011 | 04:14 PM
captng1's Avatar
Default Crank Position Sensor
I have a 1995 C280 and appear to have a bad crank position sensor. Can you tell me where it is located on the engine, and what is involved to gain access and change it?
Thanks For Your help,
captng1
Old Aug 10, 2011 | 06:30 AM
platonmind's Avatar
POSITION: on rear left of engine, above the starter.
TASK: detecting the crankshaft position and engine speed contactlessly by means of the segments or teeth of the driven plate.
PART: inductive sensor /coil/ with 2 pin coaxial plug contact.
Old Aug 11, 2011 | 06:56 AM
captng1's Avatar
Thank You Platonmind. It appears the only way to get to it, is to approach from underneath the car by removing the starter?
captng1
khouryjj
Sep 13, 2011 04:30 AM
bb1080
Apr 30, 2008 06:22 PM
soobieajax325
Nov 30, 2007 07:37 PM
cjshade
8
Nov 28, 2007 08:38 PM
khouryjj
Aug 2, 2007 04:38 PM
