Crank Position Sensor
I'm sorry I didn't get back here sooner. I located the part and replaced it. Thanks for the help anyway! I must say that finding the part is not the hard part. Due the fact the sensor is located between the firewall and the cylinder head, there isn't any room to get leverage on a tool to get the screw to turn. I ended up putting an 8mm torx bit on the screw head, added an extension to that, and then hooked a nut driver in to the end of the extension. This made the tool about 10inches-1ft long from screw to the end of the handle of the nut driver. I was able to take a pair of Robo-Grips and gain leverage by twisting the screw driver handle. Once the screw broke free, I could actually turn it with just the torx bit in my hand.
Thanks for the good information. I'm new here and just finished replacing that cps "B". In the process I broke a hose connection which I do not know what it is, it goes attached to the firewall into the brake master system on the driver side.
Took some pictures:
Does somebody know the name of this hose connection and function?
Thanks so much
Andres
Took some pictures:
Thanks so much
Andres
Andres
cjshade
8
Nov 28, 2007 08:38 PM
