Is it a common problem in C class model?
Hi guys, I need your help. I started my 01 c320 and 3 blocks later it died, it's powering everything but I tryed to start (Ignition) and nothing happens, no starter.
I did check the fuse and it's fine then I plug OBD II or whatever and couldn't
read the car computer and diplay error.
Please I need your help.
Thank.
Thank.
Looks like you have the same problem as I had. About a month ago, it did not start (early in the morning at my garage). It didn't even crank. I got it towed to a garage. Actually they didn't do anything, but it has been working fine so far.
I didmy research here. Many people experienced the similar, but their cars at least cranked. Seems like crankshaft position sensor is pretty much the cause of the problem, but I don't know if this is the same case as mine.
I am wondering if you car intermittently starts and stops, or it hasn't been working since it didn't start.
Scuddog
Dec 26, 2012 12:17 AM
