Common C280 problems
I just bought my 98 C280 with 160k miles on it and am concerned about two common problems I have been told about. The first is the wiring harness and the second is the head gasket. I have three questions... First is should I just replace them now? And secondly is this a do it yourself job or a pro job. Last, how much can I expect to spend on both if I do it or pay someone to do it? I do have a close friend that is a mechanic, and I feel reasonably sure we could figure it out if we got good advice on the procedure from a manual or something. Thanks for your help in advance.
I have the same 2 problems on my '95 C280, but I just bought the car and are under some kind of warranty. The head gasket drips oil and the wiring harness has exposed wires. Going to try to get the owner to repair it under warranty. It's not causing me any problems, but shouldn't be like that. I hope he agrees. I certainly don't want him to take the 'well, it's not broken, so I'm not going to fix it' mode.
try and get them fixed, because it wont take much for them to turn major,
Any playing with the wires could cause them to go bad.
firstly ask him to just do the headgasget, and in theory the wiring will need to be done at the same time as it will most likely get ruined taking it off for the head gasget, cos if you plonk it all on the previous owner at once he may run away
nah the new head gasget will fix the leak, just make sure it is the head gasget leaking.
and hopefully you need to replace the wiring harness at the same time, cos it will probebly go at some time in the future but it will be better for you if it happens under warrenty cos the wiring harness is like 1-2k to fix
rxk2303
Feb 22, 2008 01:43 PM
