COASTAL motor oil & C230 Kompressor???
hey guys , does anyone know anything about coastal motor oil , and if its good for mercedes C230 komp plz i need info about it ...thank you
for more info im using : 'Coastal Synthetic Blend 10w40 '
Link to webpage for approved MB motor oils:
http://www.whnet.com/4x4/oil.html
The oil spec minimum requirement varies with the year of the car. As long as the oil meets the spec it should be fine even though it's not listed.
my car is yearmodel 99 and in USA their using for it 10w40 ....and here i dnt know what to use..
so can u check it for me cause i did but no info about it and i check under 'Vehicles with the Flexible Service System FSS from MY1998-2004 can use 229.5, 229.51 or 229.3 oils.'
and i didnt see any important info
A Google search didn't turn up any information on Coastal Oil products.
What you need to do is look at the specification for Coastal Oil that should be on the packaging.
For instance, Mobil 1 0W-40 Fully Synthetic haslisted on it's container that it meets MB Spec 229.5. It also lists an API specification ofSM,SL/CF. API is a petroleum industry trade association.
Soif the Coastal Oil Product has either the MB or API specification that is appropriate for your vehicle. It would be OK to use.
the API is on the package , i know about it but the main idea behind my question is that in USA do you use this kind of oil,cause the firm of it is in USA , thank you ...
by the way how to know the quantity of i need it when change the oil...
this url lead to the firm of production:
http://www.rosenet.org/heilmann/quakerstate.htm
