Clutch pedal dropped to floor C230, W203, 2003 yr
Old Oct 16, 2018 | 02:07 PM
PhoenixGA's Avatar
Thumbs down Clutch pedal dropped to floor C230, W203, 2003 yr
My 2003 c230 kompressor manual transmission clutch pedal was "soft" and had problems shifting gears / choppy.
Then clutch pedal finally stopped bouncing back from depressed for gear engage/change and remained stuck to floor .
Clutch pedal now stays on floor. When lifted up it drops back down.
Brake fluid leaked dropped on ground , area under transmission.
Any assistance to solve this problem appreciated.
Old Oct 16, 2018 | 03:52 PM
PelicanParts.com's Avatar
Hello and welcome to the forum! It could be that your clutch slave cylinder needs to be replaced. Please let us know if you have any other questions.
Old Nov 3, 2018 | 02:01 AM
mrcdscnr's Avatar
Firstly, get well soon. You can repair it yourself when the clutch is broken, but it is an easy problem.
If you do not know the repair at all, definitely show it to a master. If you say you can do it in general, see here:
https://bilgihanem.com/
Like I said, if you're unfamiliar, don't get involved.
Phoenix999
Jun 28, 2018 07:41 PM
elfaro
Jan 31, 2008 04:19 PM
mat24
Dec 23, 2007 01:55 PM
ZBenz
Oct 10, 2004 07:59 PM
