Climate control panel, not lighting up
Old Sep 17, 2004 | 04:03 PM
GTiSTiLE's Avatar
Default Climate control panel, not lighting up
1998 c280. the climate control panel isnt illuminated. ive checked all the fuses, and they are all good. i was going to post and ask first before i start taking it apart. is there one bulb that needs replaced? or is there a deeper problem??? pics would be appreciated and any respones. Thanks
Old Sep 17, 2004 | 08:24 PM
sleepwalker's Avatar
Default RE: Climate control panel, not lighting up
i can send pics ans instruction if you give the VIN number.
Old Sep 17, 2004 | 10:14 PM
GTiSTiLE's Avatar
whats the vin have to do with it???
Old Sep 17, 2004 | 10:37 PM
because we so many variant and versions on air conditioning control unit. i want to know which one is yours to avoid giving wrong information.
you make a drawing, photo, or give the control unit number too.
Old Sep 17, 2004 | 11:07 PM
GTiSTiLE's Avatar
ill have a pic of the climate control up in the next few minutes
Old Sep 19, 2004 | 07:58 PM
GTiSTiLE's Avatar
heres a picture of the unit in question. thanks in advance for any info
Old Sep 20, 2004 | 01:18 AM
it's the new AAC version.
make sure rheostat works good.
[IMG]local://upfiles/1/735F55AF11D24B93A9D8944A18B720F2.jpg[/IMG]
Old Sep 21, 2004 | 01:54 AM
GTiSTiLE's Avatar
how do you get the panel that's around the radio and climate control unit off?? is there screws (and if so where?) or does it pop off with a screw driver or what? i havnt actually had MY hands on, im trying to best explain how to do this to my mom and step dad since im away from home right now. any more specific instructions would be appreciated. thanks for the diagram
Old Sep 21, 2004 | 05:52 AM
  #9
eugene97w202's Avatar
i just recently changed the bulb, it's a simple process, just take out the climate control panel w/ the mercedes tool, and it's on the bottom, it's this little white screw w/ the bulb connected to it... just replace the bulb, and the climate control light will appear again. I just had the same problem recently, and now it's working fine again.
Old Sep 21, 2004 | 06:04 AM
  #10
in order to remove the climate control panel.. you need these tools. you see in the picture of your climate panel, below auto and circulation buttons (opposite side of the auto) there's alittle slot where you stick these tools (i'll have the picture at the bottom) in and just pull the panel out, but you can't just buy these tools anywhere, they're pretty expensive. I haven't tried using a screw driver or anything, but it's just easier if you can find a place that specializes in mercedes, most likely they'll have the tool.
[IMG][/IMG]
[IMG]local://upfiles/3253/AE0618F813734E87A3E0AF7B20710382.jpg[/IMG]
