cl203 no speedometer/ABS/ESP/BAS
Hello
My 2001 C180 Sportcoupe has a problem. After a powerwash my speedometer stopped working along with the abs, esp, bas systems. I have no idea if it's actually water damage as no fuses are blown and I don't know where else to check.
After many hours of googling I found that people have replaced rear wheel speed sensors or the brake light switch and got it fixed. The obd scanner showed faults with CAN communication with control unit N47-5(ESP, SPS and BAS control module P0600) and also wheel speed sensor(P0500). So from that, could it also be the yaw rate sensor or esp module?
Any help would be appreciated.
