Check Engine Light
Old Jan 27, 2007 | 08:13 PM
eb2143's Avatar
Default Check Engine Light
Code PO170, Fuel Trim Malfunction...
What is fuel trim
Where do you look first in troubleshooting the cause of this code? Reset once, came back two days later.
PS Holy ****, that 2008 C-Class is beautiful!! I'll take the V6 CDI Anybody know what engines are bound this way?
Old Jan 27, 2007 | 11:24 PM
xvvvz's Avatar
Default RE: Check Engine Light
If you read lots of MB discussion boards, this code is most commonly caused by a problem with the MAF/Mass Airflow Sensor. Do some research on this. You may be able to just clean it with some CRC MAF spray or you may need to replace it. I would try the spray first for $6 at Pep Boys. Simple to uninstall and reinstall.
nolen01
May 7, 2015 05:58 PM
solarant
Dec 27, 2007 11:34 AM
krisgt2@hotmail.com
Sep 28, 2007 01:41 AM
