C36 Oils
C36 Oils
Hi everyone
The time has come for me to do a big service on my C36, its an auto with the elctronic lsd.
Ive got my coolant and all filters sorted courtesy of mercedes,
However im not sure what sort of Auto trans fluid i should be using? Theres many to choose from - would these transmissions run a Synthetic oil?
And the differential - what sort of oil (lsd/ normal gear oil?) and what viscosity should i be using?
Thanks so much
Blake
Thanks so much
Blake
RE: C36 Oils
ok for starters you have a electronic trans. you dont need to change the fluid and filter for 100k same with the rear differential.
second be sure to use mercedes benz trans fluid in that trans nothing else you can use regular gear oil for that differential. 90w
