C320 Rear Wash Wipe
C320 Rear Wash Wipe
Hi
Your assistance please o wise ones ...............
Just bought myself a C320 Estate (2003) and my rearwindow washerdoesn't squirt any water
Does anyone know if the water supply to the rear wash wipe comes from the front water bottle in the engine bay or is there a rear bottle that has to filled as well.
There is no mention in the manual !!
Thanks in advance
Thanks in advance
RE: C320 Rear Wash Wipe
I speculate there should be a reservoir in the rear - just speculation. Otherwise the tubing would be silly long to get the water from the front to the rear of the car.
Do you hear the pump going when you try to squirt water?
-Eric
-Eric
this is a wagon right? Its in the back panels in the side cargo area open up and you will see rubber tubes there. look carefully you should see the hose off. that was the prob I had. maybe pump is bad swith the hose for front washer to the other washer pump, check to see if front washer is activated by the turn signal stalk and the rear by the swith on the dash. but try to swith hose on pumps to see if clogged.
Mywifescar
8
08-26-2008 12:17 AM
