C280 repair problems
Old Feb 19, 2004 | 11:20 PM
msarno's Avatar
Default C280 repair problems
I had my 1996 mercedes C280 in for repair for an oil leak, two weeks later & $1446. they replaced the timing cover gasket set, crankshaft seal, chain guide, gaset senter,upper cover seal,& Harmonic balance pully assembly, and then set up chain & valve clearance. The car now runs very rough, has bad pickup and sounds like it is miss firing under the hood when taking off from a stop only, also lacks power on the hilly roads where I live. I just droped the car back off at the shop that did the repair. I feel that I should had had a Mercedes dealer do the work.Any recommendation?
Old Feb 28, 2004 | 12:40 AM
Lugnut's Avatar
Sounds like a tale for a consumer advocate televisionspot. </P>
Also sounds like a vacuum leak.</P>
White06c280
May 30, 2011 05:29 PM
BENZGAS
Jun 28, 2009 08:12 PM
jamesjedi
Jan 21, 2009 02:15 PM
C280 SPORT
Nov 20, 2008 05:41 PM
photog3740
May 18, 2006 03:40 PM
