C280 Oil Change & Plastic Cover
Old Sep 3, 2005 | 04:08 PM
fly_major_fly's Avatar
Default C280 Oil Change & Plastic Cover
Is it true that under-body plastic cover has to be removed to access the drain plug?
Old Sep 3, 2005 | 09:06 PM
C280's Avatar
Default RE: C280 Oil Change & Plastic Cover
yes, unless you cut a hole in it
Theres only like four 8-10mm bolts holding it on tho
Old Sep 3, 2005 | 11:21 PM
C280 wizard's Avatar
Most dealer drain the enginer oil from the dipstick, this is an approved Mercedes Benz way. I have have a pumpt and canister I got from www.griotsgarage.com for around $70 with shipping. The filter is on top of the engine, total cost is a lot cheaper then the $120 or so I paid at Mercedes.
Old Sep 4, 2005 | 02:47 PM
SL600_Cruzin's Avatar
ORIGINAL: fly_major_fly
Correct -- Like C280 stated, it's easy, only a few bolts holding it in place.
ORIGINAL: C280 wizard
The reason most dealers do it is because it takes less time, and time is money.
Personally, I would never siphon the oil out of anyone's vehicle. When I do an oil change it gives me the opportunity to check everything else while I'm down there.
That's just me though.
milaruben
Jun 7, 2011 01:59 PM
Brndnb02
Oct 11, 2007 04:33 AM
markcheng
Apr 30, 2007 05:59 PM
timharrisjr
Mar 26, 2007 09:56 PM
evozine
Mar 20, 2006 03:04 PM
