C240 Will not start
Old Jun 6, 2012 | 11:31 PM
Stanga's Avatar
Default C240 Will not start
Hi, I've got a 2002 C240 (203 series) that now won't start. Found it has blown fuse #52 in engine bay fuse block, which according to the legend is for the start enable circuit. Fit new fuse and blows as soon as key turned to start position. Would anybody know where to get a wiring diagram and component location to trace fault.
Old Jun 20, 2012 | 06:47 PM
PelicanParts.com's Avatar
Default Answer
Here is a link to information that may help you.
Mercedes c240 2001 intermittent starting problem. - JustAnswer
roy@pelicanparts.com
Old Jun 21, 2012 | 06:37 PM
Stanga's Avatar
Thanks for the reply, changed fuse to 20 amp as stated (found same info on web) but still blew fuse, disconnected start solonoid trigger wire, fuse Ok, replaced starter motor assembly, All ok so far (2 days)
patricknif
Mar 4, 2012 06:38 AM
Paul Dalton
Feb 7, 2012 02:37 PM
87MBZTurbo
Aug 30, 2009 06:06 PM
washoor
Aug 28, 2006 11:53 PM
EuroKRN
Dec 27, 2005 02:14 PM
