C240 Trunk won't open - Help Please.
2001 c240:
Trunk will not open with keyless entry key-fob, I can only access the trunk manually with the valet key. It's not the key-fob, bc's unlock and lock options work for the locks. Anyone know what I should check, or know the part if any I need to change to repair this problem.
Thank you.
Thank you.
If you have a 2nd key-fob, you could double check and make sure it's not the 1st one. Does it make any noises?
Just a guess; but I would think that it has something to do with the wiring or components that are used for the auto release, and not the key-fob.
eliteproxy
02-26-2012 02:28 PM
dee2000
07-21-2011 07:43 PM
dgrover
09-03-2008 08:47 AM
