C240 help....auto transmission problems shifting
Old Apr 17, 2007 | 03:07 AM
AAmais88's Avatar
Default C240 help....auto transmission problems shifting
I've got an '02 C240 and recently, when it's been pretty cold out and the car hasn't run in a few days, it doesn't shift out of 1st gear once the car is in drive. Like I said, it's not a regular occurence but enough to be annoying. I was just wondering if anyone had any idea what the problem may be. The thing is that if this does happen where it won't shift and i put it in park, turn the car off and then turn it back on immediately, it'll run fine. Thanks for the help.
Old Apr 17, 2007 | 10:02 PM
rohitsagar's Avatar
Default RE: C240 help....auto transmission problems shifting
I had same thing, but I think it is normal. When it gets cold out there , car takes a while before it shifts automatically to 2nd gear. I assume coz car takes a while to warm up. Try out one thing. Start the ignition in Park and sit for a while to allow the car to warm up then start driving. So that it gets warmed up enuf
Old Apr 19, 2007 | 01:21 PM
james007's Avatar
Mines does this when the engines cold. Once its warmed up abit it should go back to normal gear changing. Is this the case with yours??
elf1973
Jun 15, 2009 09:13 AM
AMGMercedes
Dec 7, 2008 04:03 PM
02c240
Jul 21, 2008 04:57 PM
axe_360
Mar 28, 2008 12:42 AM
Kustom_sounds
Nov 1, 2005 11:08 AM
