C220D YEAR 1996 NEEDS 3 ATTEMPTS TO START IN THE MORNING
Old Jan 11, 2006 | 07:36 PM
javednazeer's Avatar
Default C220D YEAR 1996 NEEDS 3 ATTEMPTS TO START IN THE MORNING
Help please, my merc C220D year 1996 needs nearly 3 attempts before it can be started in the morning. I have it checked and they said the glow plugs are all ok and they suspect air lock which happens at night. Is this true or they are trying to rip me off!!! Please help me sort this problem out. Thank you all.
Old Jan 11, 2006 | 10:44 PM
sleepwalker's Avatar
Default RE: C220D YEAR 1996 NEEDS 3 ATTEMPTS TO START IN THE MORNING
it can be true. air bubbles in fuel line.
you can install separate shutoff valve for it.
[IMG]local://upfiles/1/12536649B3DD4C19A027CE06BD80DF65.jpg[/IMG]
Old Jan 12, 2006 | 12:39 AM
C280 wizard's Avatar
Yep sleepwalker is right. What kind of climate do you live in? Perhaps you need a block heater if your in a cold area?
Old Jan 12, 2006 | 05:32 AM
Hello there, I am actually in England, London and at the moment it is very cold 3-5 degrees. Well do you think a shut off vavle would cure the problem. Also would you please let me know where can I get these and from the picture I can't get an idea where to fix the shut off vavle. Thank you very much for the help. Thanks.
Old Jan 13, 2006 | 11:34 AM
m@nticore's Avatar
this is normally caused by the feed lines to the high pressure pump leaking and they may need replacement.
Old Mar 9, 2009 | 05:57 PM
gonimj's Avatar
are these feed lines cheap to replace, coz i am having the same problem with my c220d. do we need to change the high pressure pump aswell. please explain in detail. thanks.
Routemaster
Sep 26, 2011 07:46 AM
Routemaster
Sep 23, 2011 01:56 PM
Spikeymikey65
Apr 7, 2011 09:24 AM
khickey
Jun 5, 2007 08:34 AM
icetwister
Oct 10, 2006 08:43 AM
