C220 CDI no battery no trunk
Good evening,
I need help with a Mercedes C220 CDI 1998.
Was stopped for a long time and was out of battery due to the death of a family.
Right now nothing works except opening the driver's door with the key manually.
As the battery is in the trunk, I can not open with the manual switch, so you can load to the battery.
Someone tell me what other alternative exists that can put the car to work, or another way to open the trunk.
Thank you.
Joćo Tarrafa
Thank you.
Joćo Tarrafa
ok wat u need to do.jack the car up the front,on the left side front towards the passenger front there will be a plastic cover there, remove cover,this is your live point of the car as in battery positive+,fit jump lead positive on,negative should be on body,after fitting the leads oprete key fob the trunk lock will open....
dee2000
Jul 21, 2011 07:43 PM
